Hello Guys,
Still loving my 911 ..
There is a slight squeak sound when I turn left between 10-20 MPH Front Left Side Wheel, is this common and if so could someone point me in the right direction?
Is it my CV Joint?
2006 997.1 S
Manual
48K Miles
BIG Thanks in Advance
:renntech:
These symptoms are often linked to the brakes, pads/rotors. I would check that out first.
I'd say power steering if came from rt side too. CV would be from rear unless you have C4. CV doesn't squeal in my experience, more of a vibration when accelerating from a turn.
So brakes are good place to start. Make sure left caliper torqued correctly first.
