Just bought a 98 Boxster with 69k two days ago. When I turn the key over to start, the hazards begin flashing. Pushing the hazard button on the console has no effect. Only by taking the key fully out of the ignition and restarting the car can I get the hazards to stop flashing.
Is this some kind of warning that Porsche engineered into the Boxster or is mine just loopy?
D. Massey
maybe the switch is faulty and is not actually releasing, you could pull it out and try to clean it, warning, I belive its tied into your signal lights so you will be without signals while the switch is out
