Hello,
I'm new to the board and so far love it! You guys have some great input!
Anyway I just picked up a 2004 Cayenne Turbo and the navigation isn't working. I have the Porsche nav DVD in the head unit and when I go to enter a destination it says "route guidance not active" so then I go to NAVI settings and try to check the "active" check box and it does for a brief second but then un-checks itself.
Things I done...
Checked to make sure it's the right disc and as far as I can tell it is. It says North America Map Disc or something like that. It has the DVD logo on it where as the second Porsche disc is only a CD. Neither of the discs work.
Checked to make sure the actual GPS locator works and it does, under the INFO button I show 10 satellites tracking me in 3D and it gives current long and lat readings. I also get correct elevation readings.
Checked to make sure map disc isn't scratched or damaged and to the eye the disc looks very clean.
I looked under the passenger side seat for the DVD player that is mentioned in the manual but all that is there is a slide out fire extinguisher.
I'm running out of ideas here guys, please help.
Thanks for your time in advance!
Hello,
Things I done...
The 2004 Cayenne has a PCM 2.0 based system and used a CD in the head unit. 2005/06 and later use the 2.1 PCM head units and access a DVD drive below the passenger seat. Hope that helps.
