Hi there - I have accidently put a CD into the CD where the PCM /NAVI unit is - problem is I think it is stuck as I cant get it out - Ive used Tweezers but they are too sensitive to get the CD out !!
1) You have posted in the 987/1 (Boxster) forum, do not expect a lot of response.
2) I understand that the car is a MY06 Cayenne, with PCM 2.1 DVD navi. drive (under the passenger seat) and audio CD slot on top of the PCM unit, so where exactly have you put the CD in?
3) A manual is recommended, given the problems that you have (see also your previous post)
If it is not possible to remove the disc without damaging the PCM inside, remove and disassemble the unit, or visit an audio specialist which is probably the most safest way.
