Hi all-
I enjoyed a nice drive 2 weeks ago but now the car just won't start. It will crank just fine. When I turn the key on, there are different clicks coming from both the front and back of the car as normal, but it never fires. I do not smell gasoline from the tailpipe, so I assume it's a fuel pump/hose issue. The fuses are all fine. I took the battery out and removed the wires, hoses and black retaining ring from the top of the fuel sender unit. I can pull it up about 4 inches, but then it won't come out any farther. The hoses appear okay, but I can't see them all. So, what is the trick to getting this all the way out? I'd like to inspect the hoses before buying a new pump. Or let me know if you have any other suggestions for my starting problems. thanks so much in advance. -Mike
2000 Carrera 2, 6 spd, US version, 36k miles
Hi all-
i have the same exact problem. i am replacing the fuel pump today. i will let you know if the new one fixes the problem.
Before you go to the trouble of replacing the fuel pump - check the fuel pressure and the delivered volume.
Nominal test pressure values:
Stationary engine: 3.8 +- 0.2 bar
Engine idling: 3.3 +- 0.2 bar
fuel delivered volume:
Quantity supplied must be at least 850 cm3/30 sec
i.e. after 30 seconds at least 850 cm3 fuel must be present in the measuring container.
Would this tool work to establish fuel pressure / delivery qty.?
http://www.amazon.com/Fuel-Pressure-KAL2530-Kal-Equip/dp/B00063V2VC/ref=sr_1_4?ie=UTF8&s=automotive&qid=1272052886&sr=1-4
JP
http://www.amazon.co...72052886&sr=1-4
JP
If it comes with the correct adaptors, otherwise no.
Here's my DIY article on removing and installing a new pump (It's nearly the same as the Boxster): http://www.pelicanparts.com/techarticles/Boxster_Tech/22-FUEL-Fuel_Pump/22-FUEL-Fuel_Pump.htm
Using the instructions in the article, you can "jumper" the pump and test it. Chances are if it's flowing, it's probably good. These seem to fail outright - they don't really fail with low pressure problems...
Hope this helps,
-Wayne
Awesome! Thanks! I've been away for a while, and I'm glad this thread lived on. My car is still dead in the garage. So many nice spring days are slipping by. Once I get a chance to tackle this again, I'll post my results.
Before you remove and replace the fuel pump, you might want to investigate the serviceability of the crankshaft position sensor. Recently, there have been a couple of Boxsters I know of that have had the same symptoms. The fix was to replace the sensor. Apparently, a bad crankshaft position sensor will preclude the fuel pump from powering up....leading to misdiagnosing the failure to start problem.
Bill
Bill
Which would throw a code......................
Too late. I just got the pump out (after hand pumping a full tank out and into my truck). The pump and hoses look okay to me. But since I don't have a code, I'm assuming my problem is fuel supply related. I guess I'll just install a new pump and see what happens. Stay tuned.
Update: I ordered the following parts...
Fuel Pump
VDO Fuel Pump 911 VDO Price: $215.95 Qty: 1.00 Part #: W0133-1599720
Fuel Sending Unit Gasket
OES Genuine Fuel Sending Unit Gasket 911 OES Genuine Price: $8.95 Qty: 1.00 Part #: W0133-1646700
Fuel Filter Mahle Fuel Filter 911 Mahle Price: $37.95 Qty: 1.00 Part #: W0133-1624873
...and so far have dropped in the new fuel pump. I crossed my fingers and turned the key. It started right up after a few cranks! :thumbup:
Side note: This problem started right after I dumped a bottle of fuel injector cleaner in the tank. It's probably just a coincidence, but you have to wonder if that did something to clog up the filter which would put additional strain on the old pump. Either way, I'm going to replace the filter before I drive it. After getting the car up on ramps and seeing the underside of the car for the first time, this looks like it's going to suck. However, I am constantly marveled by the engineering of these cars. And it's nice to work on something for once that you don't have to upgrade every single part- unlike American cars. "Stock" must not be a bad word in Bavaria, eh?
Help, looks like I have the same issue but the fuel pump is dead... any easy way to drain the tank without the fuel pump working?
Speedracer, I know this thread is old but where did you buy your parts from? Great prices!
David
Well, just finished this project up... not too bad. About 2 hours total including the fuel filter replacement. I had a little under a half a tank of gas so I just used gloves to remove the pump. Everything was pretty straight forward, and I did this out in my driveway to keep the fuel fumes from being an issue. :)
