Installing Adjustable Thrust Bushings
DIY Install of Thrust Bushings     I bought adjustable thrust bushings and did a search on how to instal them... Nowhere did I find one...so...   OEM Bushing, ERP Bushing and Stock Control arm:   The tools I used to press out my bushings:   You also need 18 and 21MM wrenchg/socket tools.   Heat the bushing steel sleeve (the part the rubber resides in) for about 45 seconds to a minute... Then take the hammer and the seal driver and drive the bushing up...   Installed Bushing:
