5 Bar FPR upgrade
*This mod should be done along with your software upgrade - Coordinate with your tunere first before installing! 5Bar FPR - DIY     The key is to follow these simple instructions:   HAVE A MANGET HANDY, YOU WILL DROP STUFF.   Have a DECENT LIGHT HANDY. You'll need it to see the stuff you drop!   Unbolt the metal clip that holds the oil filler neck and rotate the neck counter clockwise and slide it up and out of the metal bracket. You can see a groove in the air pump bracket on the left
  • 4 years later...
Nice post!
I was unable to remove the oem fuel regulator and install the 5 bar until I removed the driver side turbo and used a really long screw driver. My hands are big and I was not able to get enough leverage top side.
