Hi - I am not sure where the leak is coming from myself (I am new to Boxsters), but I do have some oil in the same place on my 97', though not quiet as wet as the pick you have posted. From dealing with oil leaks in the past, I know that cleaning it off well with a good cleaning fluid then running the vehicle for a few miles will make it a lot easier to spot the source of the leak. Sorry that's all the advice I can offer, hope you solve it.
Andy
Could be the rear main seal.
Andy
Anybody knows what this oil leak could be? See the picture.
hello
i have a 1999 boxster 2.5 it has the same leak,it went into kendal porsche for something else and the mechanic told me the leak was the rear crank oil seal,its very common on 986s and 996s dont worry when your clutch needs replaced have it done then. ronnie
