Hi
Has anyone done the resealing procedure on the Oil pan on the 996?
I have a fresh tube of Loctite 5900 FLACHENDICHTUNG (Flange sealant).
Anyone done it? Any Tips? Besides lots of Rags?
Should be pretty straightforward (and messy).
The oil to to crankcase bolts only get 7.5 ft/lbs (10 Nm) so do not overtighten them.Also Porsche says use only Drei Bond Silikon - type 1209 -- within 5 minutes of applying.
