Hi all - I would like to know how best to maintain the window seals on a cab. There is a combination of rubber and felt and to make the window closures waterproof and squeekless, can I use vaseline (petrolleum jelly) coating on the rubber? what would I use on the felt? (I am not even sure if it is felt or worn down rubber)
Help most appreciated - thanks!
Don't use vaseline. The best is silicone grease. It's also know as dielectric grease. You can get it in tubes or in spray bottles at the auto parts store.
I wipe mine down with a damp towel to remove the grime, then once they're dry, I'll slather them up with the thicker silicone grease that comes in a tube. I'll let it sit overnight, and then I'll wipe it down to remove the excess.
I do that about every six months to keep them from squeaking or sticking.
