Hi everyone,
Is there any way to set the climate control so that when I turn the car on, the AC is automatically in the OFF position?
For some reason, whenever I turn the car off with the AC off, when the engine is switched back on, the AC is in the on position with 1 bar.
When I turn the car off with more than 1 bar, lets say 3 bars, the car remembers this setting and turns on with 3 bars.
How can i get it the car running and the AC automatically be off?
Thanks!!
I have a 1999 Porsche Boxster.
- Mike
Hi everyone,
Thanks!!
- Mike
i have the same problem, actually I hate it!, no matter how many times I turn it off, it comes back on
You can take out the fuse.
I believe that if you hit the 'snowflake' button, the compressor will stay off next time you start the car, but the A/C will always return to "Manuell".
You have to hit the (-)minus button to return it to "Off".
