I just read about fixing my steering wheel horn by changing the bushings. The problem is that I can't seen to get to the two screws in the back. I tried a phillips screw driver without luck. Does anybody know if it's phillips or some special screwdriver you have to use?
I have a 1999 carrera 4 convertible.
Kristian
Those two screws are a torx and I believe it's a T-20, but don't quote me on that.
Rick
99 996C4
87 944S
Kristian
1999 air bag bolt is a T-30 (p/n 999.073.134.02)
It takes quite a bit of torque to get them out. The replacement bolts also come with blue thread locker already on the bolts (grade 8.8)
