Hallo,
I'm new here so forgive me if this toppic is not in place.
I have a problem with the rear PDC
When i put the car in reverse, only the outher red leds turn on whith a short beep.
There is nothing behind the car !
In front everything is working fine.
Can enyone help me whith that.
Thx.
New Posche member ;-)
All you need is a PIWIS or similar diagnostic tool to read out the present fault codes, most common are sensor failures, check if all of the rear sensors are free of scratches and damage, usually both outside sensors (above the exhaust tips) and connectors are full of mud, try to clean them. If no result, get the codes read.
