Need recommendation on what kind of tires I should purchase. I currently have a lot of road noise coming from the rear of car. I have a 2000 Boxster 75,000 miles. Bought the car with Goodyear Eagle GT 255/40zR17. i think the noise is from tires not from bearings but not sure how to tell. Front tires are 205/50R17 so don't think i can rotate. Can anyone recommend tires that have low road noise?
I can think of three places the noise may be coming from, tire noise, brakes, or wheel bearings. Drilled brake rotors make a wup wup noise like a weedeater, wheel bearing noise changes with load on turns, and tire noise is speed dependant You can change ia pressure, maybe add a little to see if the noise changes. Most aggressive tires have noise, I've found the reviews on tirerack.com helpful about what brand is quieter. I have cheap tires, and they've been noisey since i bought the car, will try something different next time.
I'm accross the river if you want to meet up and compare noise, my S is one of the noisiest cars I've even owned, but wow. Chuck
Thanks someone else recommended the Hankook Ventus V4. Think you can get them at Sears. It would be nice to compare sometime. can contact at ibnole@comcast.net Thanks.
  • 4 months later...
I had to replace my Michelin PS2s on my 2007 Carrera as they were getting down to the tread wear bars after 20K miles. They were incredibly noisy above 50mph. I research things to death and decided on the Hankook Ventus V12 EVOs. From Tirerack, 4 tires cost me $835 delivered plus $210 for installation. Glad I did as they are really quiet. I don't have PASM so I was looking for
a less noisy tire that performed well. I run them at 48 PSI and I really can't see much of a loss in performance over the Michelins that are twice as expensive.
