Forgive me if this has already been covered, I did a quick search and could not find exactly what I was looking for. .
Currently I have a CR-210 in my car i beleive ( cassette with 6CD under the hood ) , and i want to switch over to a CDR-220 (Single CD fold down faceplate ).
I was wondering if this is a direclty plug and play application as far as the wiring goes, or if any modification would be needed. Also Would the CD changer under the hood still work?
Im sure there are lots of ppl that have swapped out the Cassette deck, any feedback on what you did and how easy or difficult and how you like it would be much appreciated.
The CR-210 can be switched out to the CDR-220 very easily. The 210 has a sleeve that will need to be removed. The same radio removel keys are used for both the 210 and the 220. All harnesses snap into place in the 220 as the 210. Go fo it.
