When I start off in 1st gear, there is sometimes a kind of pop noise that sounds like it is coming from the right rear wheel. Anyone else familiar with this?
David
I've noticed this as well. I have a couple of theories.
It could be movement of the brake pad within the caliper. I had this issue with the front brakes. I fixed it by placing a little sticky back soft shim (the kind usually used on the back of the pad to reduce squeal) on the two points of each pad front and back where it contacts the caliper.
It could also be a worn ball joint or other suspension piece that's allowing some movement.
BTW, I think this post is probably in the wrong section.
