Help! I have a 2005 911 C2S with 64k miles and suddenly had a rough idle at a stoplight. no check engine light. parked it for a week, cranked it up and large puff of blue smoke, still rough idle. Any ideas on what it could be?
Any help would be greatly appreciated!
When the smoke first started it was at start up only... I cleaned the throttle body and I think I fixed the rough idle. I cranked it up and a large billow of smoke puffed (blue smoke) but stopped at idle. As soon as I drove it (put some load on the motor) it smoked every time (like at a stoplight take off) so I have parked it until I can get it fixed. Is it a 3.8 L C2S... The check engine never blinked, just popped on and stayed lit.
Read other posts here on cleaning the throttle body.
What engine size is this? 3.6 or 3.8l?
This can be the Air-Oil seperator as well as a problem with the cylinder walls being scored. This would require a Bore- scope to inspect the walls.
Pull codes with a generic scanner if possible. Did your check engine light start blinking when the rough idle occurred?
S.Vizcarra
Porsche MeisterTech
http://meistertech.blogspot.com/
3.8L, Smokes on start up and when a load is put on the motor, large amount of smoke... I am scared to crank it as I do not want to do more damage. The check engine light did pop on but never blinked. I cleaned the throttle body and I think I have fixed the rough idle.
Comes the smoke from one or both exhaust tips? From only one tip could be an issue on the relevant cylinder bank, on both tips something general as a crankcase breather issue, too high oil level, etc.
Smoke only comes from the left exhaust... cranked for the first time in a week last night and the smoke was more white, but thick. car runs great, just smokes like heck. I towed it to the shop today. What in your opinion could it be?
The 05 997's are unfortunetly known for engine issues. Porsche has been very good about covering engine repairs/replacement in the 05's even if out of warranty.
Hopefully yours in not serious. Although smoke coming from one bank of cylinders is not a good sign.....
Good luck and keep us posted of what the diagnosis is.
I hate to hear about the 05's having trouble, I wonder if they will sell me an extended warranty? Turns out my problem was an air/oil seperator... as I had it changed and it has not smoked since. There was oil in the intake, which was a big clue. As the AOS sits above the motor on the top-left, the oil was getting into the intake on the left side, making the left tailpipe pour the smoke. I am wondering if there is anything I can do to keep the motor in top shape, as many of these posts seem to be down on the '05 C2S?
Thanks again, all.
