I need some assitance in Jumping the PINS on my 03 996 in order to stop the rear spolier light. I read the TSB which states jump pin 2 to Pin 5. However it aslo reads "new" harness. I havent changed the harness and I am looking for a way to stop the warning light without purchasing a new harness. Any help is greatly appreciated!
I did search the forum and cannot find any direction specifically to this issue.drive1.gif
To clarify, its the warning light that I need to disable, thanks!
What harness part number did you use?
Is the car a coupe or a cab?
Which spoiler did you install?
Thanks for the reply Loren, I have a Coupe, and I installed a GT3 aero fixed wing with no harness.
I appreciate the help!!!
I think you were reading the wrong TSB. The "Aerokit Cup" for the early cars (MY99-01) had instructions on how to jumper the harness but the later version does not.
You are installing the "Aerokit Cup II" (for MY02-05) which only has the harness as an option. The harness you would need is 996.612.070.51 Wiring Harness - US MSRP $123.71
Try board sponsor Sunset Imports (Porsche Parts at Dealer Cost) for a better price. You will find a Link near the top right of any page.
