Title says it all. What does Porsche list as the official TU for install of the X73 package. If there is a document that illustrated the install requirements and time charged I would appreciate it. Thanks!
Porsche never sold (to my knowledge) a retrofit kit for X73 - but Gert Carnewal does.
I would guess around 4 hours (or less) install since the springs and shocks are already assembled. Plus a good 4 wheel alignment.
Yes, Suncoast (just like Carnewal and likely others) put heir own kit together from part numbers. Not uncommon - my 3rd radiator was never a factory kit either - Gert and I put it together from the parts lists.
Well, X74 is comparable for the non-wide body cars. But basically, as I said you don't have to worry about removing and reinstalling the springs from the shocks as they will come assembled.
Ok, now that makes sense. The dealers put together a "package" and then sell it as if it was an offered p/n package to begin with. Makes sense.
Apparently there is face is an internal document for X73 install and the TU on this is absurd. 12.50 hours for install, mounts, and full alignment.
Not surprised about the time. IIRC the front axle has to be disconnected to get at the struts.
Years ago, I was quoted about $1000.00 labor plus a "corner balance" from an Indy, which I thought was weird since the X73 is not height adjustable. If he had said an 'alignment' I would have done it, but then he got all righteous about his 'experience' when I asked.
My dealer wouldn't install it." Not factory equipment" "ve vill void your warranty!!".
I gave up.
BD
