I have a 2002 c2. I just hit 51,000 miles today. When i started it up today, i got a cloud of white smoke out of the tailpipes. The car runs fine. There are no unusual noises, and no engine codes. I checked the oil and the coolant and both are fine. After a the engine warms up for a few minutes there is no smoke. Has anyone else encountered this? Any ideas what might be causing this?
HI There....
This is normal for many P cars. Usually more likely to happen after sitting for a while. Happens on 997's too. If you drive aggressively, let it idle for a few moments before turning off the engine and you will
be less likely to get the puff. Either way...Probably nothing to worry about.
Enjoy!
HI There....
Enjoy!
Thank you. That is quite a relief. I was pretty worried about it.
Is it a "cloud" of smoke or a "puff"?
If it is a thick white cloud that kills all insects in a 100 yard radius it may be your AOS. It also could be an oil "overfill" if you have recently changed your oil.
