Along with the frame/suspension issues I am trying to fix the most annoying thing is the top. IT seems shifted to the right. and catches as it comes out. WHen it gets to the front window the hook seems to miss the little pocket is it suppose to lock into. The dealer said that there really aren't any adjustments on the top so if it isn't lining up it is the frame that is off. The body shop said the frame is straight but the suspension and engine cradle oare off. I then asked what I need to do to fix the top. They said that the bushings are worn but that it would take a month or two to remove the top and replace the bushings. Does anyone have any guidance on finding or replacing these bushings? Is this a DIY project. I can't imaging replacing a few bushings would take 6-8 weeks. Any advice would be appreciated. THanks.
