Has anyone else replaced a plastic seal around the sparkplugs ? I noticed some oil under the car, not dripping, last fall before putting car away. When I took the car to the dealer for and oil change he mentioned I had a leaking seal around plug. Having seen it also I agreed to getting it replaced this spring. Now I'm thinking I should get all six replaced to avoid the problem in the future since the car is 9 years old with 53k on it.
2001 Boxster
2001 Boxster
Here is a nice DIY from Pedrosgarage.com for replacing the seals (and plugs and tubes if you decide to replace those as well:
http://www.pedrosgarage.com/Site_3/Change_Spark_Plugs_%26_Tubes.html
Regards, Maurice.
