I'm looking for the part numbers for the cables that run between the PCM head unit and the DVD drive below the passenger seat. I have a 2004 Cayenne and have purchased a head unit from a 2006 and DVD drive. Thanks,
I suggest you do some research first on whether the new style PCM will work in your car.
Go to the TSB section for Cayenne and search for the Cayenne TSBs for "PCM". About 23 TSBs as I recall, including parts lists.
Thanks, Is there anyway to print the TSB?
