Is it OK (safe) to mix some Sunoco GT+ with pump high test in an attempt to raise octane?
I don't want to do anything that might hurt the car. (2005 997s)
Not having any particular issues, but a friend just dropped off a 5 gallon can as a "welcome to fast" gift. :)
Racing gas will not make your car go faster. It will
burn all the junk out of the piston area. Always good
to run a little racing gas.
Paul
Not looking for more speed per se... just wanted to make sure that it was safe to use the 5 gallons I got as a gift.
I believe the car wants 98 octane, so I figured it would have to make a bit of difference when added to 93 pump that is available here.
