HI, new to the forum. Thanks in advance for all the great info on here. Here is what I need. Computer is throwing a code that says injector 7 failed, I ordered a new injector and I want to install it but I cant seem to find anywhere a diagram to show which is cylinder is number 7? So basically my ? is what is the cylinder layout on the 4.5 turbo. thanks in advance.
:welcome:
For the Cayenne S and Turbo (V8)
<----- FRONT
1 - Ignition bar module, cylinder 1, bank 1
2 - Ignition bar module, cylinder 2, bank 1
3 - Ignition bar module, cylinder 3, bank 1
4 - Ignition bar module, cylinder 4, bank 1
5 - Ignition bar module, cylinder 5, bank 2
6 - Ignition bar module, cylinder 6, bank 2
7 - Ignition bar module, cylinder 7, bank 2
8 - Ignition bar module, cylinder 8, bank 2
  • Thanks 1
  • Upvote 7
  On 2/1/2012 at 2:35 PM, Guetstar said:
Hi, some one can tell mr wich is the number 19 and 20 please?
thank you
19 and 20 are the knock sensors. They are under the manifold.
thank you
Thank you!!
  • 4 years later...
where did that graphic of the engine come from? I'd like to know what the other numbers are designating, too.  Thanks
