HI, new to the forum. Thanks in advance for all the great info on here. Here is what I need. Computer is throwing a code that says injector 7 failed, I ordered a new injector and I want to install it but I cant seem to find anywhere a diagram to show which is cylinder is number 7? So basically my ? is what is the cylinder layout on the 4.5 turbo. thanks in advance.
:welcome:
For the Cayenne S and Turbo (V8)
<----- FRONT
1 - Ignition bar module, cylinder 1, bank 1
2 - Ignition bar module, cylinder 2, bank 1
3 - Ignition bar module, cylinder 3, bank 1
4 - Ignition bar module, cylinder 4, bank 1
5 - Ignition bar module, cylinder 5, bank 2
6 - Ignition bar module, cylinder 6, bank 2
7 - Ignition bar module, cylinder 7, bank 2
8 - Ignition bar module, cylinder 8, bank 2
  • Thanks 1
  • Upvote 7
Hi, some one can tell mr wich is the number 19 and 20 please?
thank you
19 and 20 are the knock sensors. They are under the manifold.
Thank you!!
  • 4 years later...
where did that graphic of the engine come from? I'd like to know what the other numbers are designating, too.  Thanks
