I'm new to the whole forum thing and I think I need help. There is a sound coming from my engine or my exhaust that sounds tike a little bird squaking. It only makes the sound when the motor is under load, meaning when it is at idle or acceleration. The sound has gotten worse but has not had any noticeable adverse effects on the performance. It seems as though the sound appeared after changing the MAF sensor and steam cleaning the bottom of the motor(you know from cleaning the common leaky oil). Thank you for your help.
A sound clip might help us diagnose it more.
A squeak from the engine could be anything from a noisy mounting bush to a jammed parrot in the air intake manifold :jump:
