Most the time when I'm backing up into a parking spot with a sharp turn my front wheels/tires make a noise...maybe as if I'm dragging sideways because of the near 90º turn. It also happen on a sharp slow turn moving forward.
Is this normal?
Normal.
Park the car with the wheel turned hard. Then look at
the wheels. you will
see why it makes noise.
Paul
Edited by PAULSPEED
I hear assorted clunks and creaks at a full lock steering angle on mine as well as my Honda Element, which has a greater steering lock angle than most front-drive cars. I would consider this normal. And welcome to the Forum!
I had the same problem with a previous 2005 997S. I took it to the dealer countless times to try to fix but to no avail.
Eventually I got so tired of it that I sold it and bought another one.
Thank you very much for your reply!
I was told before by the dealer that it was normal, but I just want to be sure.
Regards,
