Hi all,
I had an unusual glitch this afternoon. I drove to the store, about 10 minutes away, shut the car off and when I came back about 15 minutes later the starter engaged but the engine didn't start. I let the starter crank about 5 seconds before selecting the key off. When I re-engaged the starter about 5 seconds later it started right up and ran fine.....I haven't checked the codes as yet, but I suspect I will have a miss fire....The only thing I have done to the engine lately is new plugs about two weeks back.....and it has been running fine.
Anyone else ever have this happen??
Rgds,
Bob
Sorry, should have mentioned: 2004 Cayenne S....
Edited by NelsonMX
Yes, sounds logical.....
I checked for any codes and nothing. I would expect a P0230 for the fuel pump primary, but nothing at all.....not even a misfire.
I had a key battery low message earlier, but this has never prevented it from starting. Does the immobilizer cut ignition?
In the meantime I have started it about twenty times throughout the day and it hasn't missed a beat so far, so maybe just a glitch!!!
Do these things have a Crankshaft Position Sensor? If yes, that's another possibility. They fail quite frequently on MB engines; and produce the exact same symptoms with no codes set.
Edited by DUTCH VanAtlanta
