I'm about to swap a 3.4L 996 engine into my Boxster and I'm wondering what changes/improvements to do while the engine is out. I figure at least plugs and a poly belt. Any other suggestions? Is it worthwhile to swap out the AOS? How about oil baffles, as I plan to use it on the track?
Edited by steve_wilwerding
Plugs, tubes, water pump, underdrive pulley, low temp thermostat, all new tensioners and rollers, oil pump..... Im sure I can think of more.. I have a 3.4 in my box too :)
You should upgrade to LN Engineering Intermediate shaft bearing and replace RMS.
+1
Depends on what year the engine was built though. I have a replacement 3.4 in my 2000 996 with 50K hard miles on it now, and still debating whether I should do the IMS bearing upgrade next time the tranny or engine is out.
JP
