Can’t find any aftermarket air filters for the 2010 gt3. Can I use the air filter which was made or 997-1 gt3? Is the air intake exactly the same on both cars?
  On 3/6/2010 at 8:51 PM, Loren said:
Unless it is a GT3 RS the air cleaners are the same as earlier 997 GT3 and the 996 GT3.
WOW that was fast .. Thanks
do you think its worth trying the whole air intake system by K&N?
IMHO - no.
It would make some difference on a turbo not much (if any) on a normally aspirated car.
IMHO - no.
Lauren,
Really not much of a difference on my GT3 RS, because the engine is normally aspirated.
Thanks for the clarification, because I was going to buy an air intake system, but obviously not anymore after learning this.
Regards,
Dane
IMHO - no.
Lauren,
Regards,
Dane
While the intake "kit" may not yield much, the BMC or K&N factory replacement *filters* are worth it. They flow better than paper and will last the life of your vehicle. Easy to clean and reuse. Water doesn't bother them either.
--CC
