Just wondering if anyone has ever dealt with the shift linkage on the transmission leaking oil, is it a difficult repair to attempt on your own? any how to's?
I think you need to disassembly the complete transaxle to replace the seal. Be sure to check the vent isn't blocked causing pressure in the case which might be causing the seal it leak. I've seen a few of these leak before but it was such a small leak it was nothing to be worried about. Check the fluid level at every service.
Vertex said they wouldnt worry about it too much either, they rebuild it 2 years ago. I am going to check the oil level and make sure it is not low. Thanks for the pointer about the vent, I will also check that
