I have a 99 Carrera Cab and need to replace the rear springs. They have sagged so that the rear is noticably lower. I searched and found how you get at the upper mounting bolts in a coupe but haven't been able to find what I have to do to get at the bolts in a cab - it's a lot busier back there. Can anyone share how I access these on my car?
Place the hood in service possition (see manual) - Remove the carpet under the rear of the hood - left and right are precut spots in the insulation/foam under the carpet and right above the struts - remove the precut insulation/foam parts.
