I have been following the tutorial by dmcole to replace the ignition lock & switch. All was going smoothly untill I tried to rotate beauty ring around the key cylinder to the 7:00 position so you can insert the paper clip in the holes that line up in the beauty ring and the key cylinder so it will release- mine won't budge. Anyone know a trick to this step?
