Hi all
my 2001 boxster s has been giving fault code P0341
I have been advised to change the camshaft position sensor?
Does any one know where it is located? I have had a good look around
the engine and can only see the variable timing actuators.
Thanks for your help,Jim
Also im quite happy to document this fix with pictures and post them up
for reference for others!
Thanks,Jim
Upper part of cylinder heads on the opposite side from the tensioner side.
should be just above(maybe below) the green plugs (where you can view the camshafts)
on the edge part of the cylinder head. One side maybe north (top) - the other south (bottom)
(I can't remember - I don't have an engine in front of me)
if you have an extra plug or two -- you might want to check that the camshaft is in deed in alignment.
you can pop the green blug (by stabbing it and yanking), than put the engine TDC. The camshafts
should be in alignment north/south with the split in the cam cover to cylinder head seam.
two rotations of the crankshaft gives you one complete cycle on the camshafts.
the green plugs just press back in -- but you need new ones.
Mike
Edited by txhokie4life
