Hi guys its looking like i need to remove the Cam cover right hand side of my c2 1998.. Is there any advice i could get from anyone.. Will i need to drain the oil or will there just be whats lerking in the cover/casing. Can any one advise on holding down the cam shafts. Will they just fall out? I need to replace the Cam Actuator, so will i even need to hold the camshafts in. Where can i get the tool from or can i make one.. Can i still get access to all the bolts with the exhaust on....Thanks
