Hi, does anyone know what could be the problem. I have a '98 Boxster and when I turn the head lights on with the engine running it works fine. when the engine is off, and I leave the lights on, the driver side stays on, but the passenger is off. My front passenger signal also doesn't work, and I'm assuming it has something to do with it as well.
I've already changed out the bulbs, and the actual headlight assembly itself, but get the same results. Does anyone know what the problem might be or have a suggestion. Please advise. thanks
