After washing th car, I get a brief battery/alternator light. Obviously from the pulley being wet and the belt slipping. Is this a tighten the belt issue or treat with benign neglect?
David....There is a known situation where this can happen if the alternator gets wet. Usually it happens when you are cleaning the engine and spray some water directly at the alternator. PAG warns you against doing this. They recommend protecting the alternator with a plastic bag while spraying off the engine. I had the same experience once.
Thanks Craig, it's not that i'm washing the engine, it's water that gets in from the decklid during a normal wash. Makes me wonder about driving in a hard rain.
