I was just curious if anyone can tell me if the 11" 997 rear wheel with 67mm offset will fit the rear of a 2007 987 Boxster S without rubbing? An offset calculator tells me that it will not stick out any further than stock, and will be ~5cm (49mm) closer on the inside of the rim.
thanks guys!
Dan
