i had a problem with my porsche boxster that the windows would not go all the way up and would stick about 3/4 of the way up, i checked all the topics and between them figured out the problem and fixed it, the problem is with the microswitch on the handle on the top, it belives its open and therefore opens the windows a crack, you have to make the top believe its closed and to do this open and shut the top, the windows will then close again, remember that a gust of strong wind or heavy rain can fool the top into thinking its open but at least you know what to do, hope this helps, ours are now closed.
