Hello All,
Bought my wife a 2004 Cayenne S. While I was away on a trip she said the drivers side headlight went out. I just checked it out and not only is the low beam not working, the high beam doesn't work either. On the dashboard it says "Check Dipped Beam" along with the i warning message. Help please, thank you.
Remove the headlight assembly following the directions in the owners manual and check the electrical connection in the fender. It's retainer can become damaged and often just the act of removing and installing the light assembly will sort things out. If you have any more questions they will be answered by doing a quick search as this subject has been covered many times.
Welcome to the forum.
