  On 2/24/2010 at 8:52 PM, Loren said:
Correct 19 mm.
I would buy 6 point sockets - they are stronger.
Great, thanks Loren. Any idea where I can get a "soft" 6 point socket that I can use with an impact wrench? A lot of the soft sockets seem to not be compatible with impact wrenches and I'm guessing it's because the "impact" from the wrench will break the "soft" socket. I'm just worried about scratching the wheels or lugs while using the impact wrench.
Thanks again for the quick response,
Jason
Edited by jfoxny
  On 2/24/2010 at 11:46 PM, mp911 said:
I wrapped my socket in electrical tape
Humm.. that's a good idea! I'm also concerned about the interior of the socket, though. I'll be using an impact wrench it increases the chance of scratching the lugs. Got any ideas for that besides not using the impact wrench? :-)
Jason
I really don't think you should use an impact wrench. All you need is a good, 1/2 drive, torque wrench, with a long handle. Spec is 96 ft.-lbs. Eat some Wheaties, you can do it!
I wonder if it would 'braek off' or if its more like rubber..
Edited by vipola
