Hi one and all.. I was reading through the tutorial for changing the fluid and filter on a 996 Tiptronic gearbox.
I'm having a little dificulty understanding what the temp probe is for and where the fluid is coming from. Basicly is the author saying that the filler hole gives the correct level of fluid at 40.C when the pan is topped up and fluid stops running from the filler hole ..Many thanks for clearing this up for me i may give it a go..
hi thanks for the reply..
So sorry to be come over a bit slow, but are we saying that leave the filler hole open and let it drain up untill 45.c is reached then close it up ...many thanks
