Well don't I feel stupid.
4th Boxster - but all my others have plastic rear windows
This is an 01 that the previous owner put a glass (looks to be factory) top on.
I tried to put it in service mode, but the glass keeps hitting the roll cage
and I can't seem to "flip it up" like the plastic ones.
Is there a trick to it? Are the later models (03-04) slightly different?
thanks,
Mike
This is one of the issues when the after market glass tops came out for the plastic window cars. The 2003-2004 cars have a 4 bow top, while the plastic window cars have 3. I think some shop was charging and extra $50 for working on a glass top car that originally had a plastic window. car.
thanks,
Mike
Mike:
If the 01's top is factory, then it should have the "PORSCHE" logo in white, centered near the bottom edge of the glass.
It it is factory, it has to be from an '03 or '04 top, and, in that case, it will fold properly when in the service position. The top edge of the glass will just clear the roll bar and you can then flip it up, but it then has to be held up with a strap that goes from the driver's side of underside of the rear main bow to the tongue on the driver's side of the front edge of the convertible top frame.
As Tool Pants says, the '03/'04 tops have a four bow frame, so it's easy to indentify.
Regards, Maurice.
thanks,
Mike
Mike:
Regards, Maurice.
I'll have to check it out the next time I'm out at the shop -- but I'm thinking it is a non-porsche glass window.
mike
I have an aftermarket GAHH glass window on mine with the original '01 frame. The glass window hits the roll bars when I fold it back, but if I push up on the window a little as I'm folding it back, it will fold a little farther and give me enough room to work. Then, I take a bungee and clip one end to the rear of the top and the other to the front . That holds the window up and out of the way. It's a little less room on an already pretty tight access, but I haven't found it to be too bad.
Here's a post with photo from another thread on Renntech showing how this is done...
http://www.renntech....post__p__117592
Edited by secretagent214
