In reviewing the wiring diagram for the CDR23 with MOST (2004 996 C2), I failed to find the terminal for illumination. What color combo of wire should I be looking for? (I like the new site layout, search function is much improved)
These postings apply to switched power (as does the CDR23 pin out). I was looking for the signal that turns on the backlighting of a gauge, switch, or in the case of a radio, its backlighting when the light switch is turned on.
The CDR-23 is a MOST component which is fiber optic linked to other control systems in the car. There is no wire for illumination - the radio handles this based on a signal over the MOST network.
You won't find a wire in the car for this.
