I am reinstalling my RemoteKey module in my 09S PDK. The original wiring directions had me tapping into existing wiring, which threw codes.
I want to reinstall by plugging into fuse block for power, no problem, But I need a good grounding place.
I would welcome a suggestion, before I retap into another unknown ground wire.
Edited by larrytrk
Use one of the screws or bolts that holds the fuse block to the body. That will work fine.
Will check this out!!
If you pop the side dash cover panel out (pop out the rear edge, then pull back), I like to use one of the dash support bolts, it's a good ground point. I don't like using the nut on the left side of the fuse box since it's holding down plastic. Just personal preference.
