I am most of the way through removing the driver side lower trim on a right hand drive 2005 Carrera S.
There seems to be one remaining attachment point around the key ignition switch, which I can not
find even when I removed the ignition. Can anyone help? Pictures would be good.
I'm not sure if it helps or not, but the US-spec version of that trim can be seen in page 301 of the 997 parts catalog:
http://www.porsche.com/all/media/pdf/originalparts/en/E_997_KATALOG.pdf
The attachment point nearest the ignition switch appears to be a screw located behind the steering column assembly. Not sure if you need to remove the steering column covers to access it, but it may be worth a try.
A search here for "+997 +dash +removal" brought up this link, which has a nice picture of the assy taken apart on an LHD car.
http://www.renntech.org/forums/index.php?showtopic=17349
The search function is great, there's a lot of excellent material covered in old topics. Hopefully, this will help you get the job done!
Good luck,
Mark
