I may need to replace my 2003 3.2 S engine. Will any year 3.2 engine work? Or were there any electrical or mechanical changes that have been made from year to year i need to be concerned about?
oh and any recommendations for trusted source for Porsche engines?
Edited by BrianH
If you want a long block get a 2003. Otherwise you can't use a 2004 because of the variocam plus. If you get anything less than 2003 you need to change the fuel ramps because of nonreturn fuel system.
I was happy with the LA Dismantlers.
Good Luck
Sergiu
Good Luck
Sergiu
So if I wanted to leave the 3.6 unmodified, but also be able to use the fuel delivery of the return systems -- what would I need to do.
In my case I'm using an Boxster 01 S to test engines, so I want the capability to run both fuel system types,
or at least I want to run both engines un modified but mod the car to run both.
ideas?
mike
