I just purchased a 2005 Turbo S Cab and want to upgrade the NAV CD's. Is there a list that shows what CD's are compatible with PCM 3.0 S/W 3.0?
I need to do the same. What part number did you order?
Try
Merchant
AX Enterprises, LLC
P.O. Box 130039
Carlsbad, CA 92013
United States
760-877-3872
I ordered these a couple of weeks ago.. gently used and they work just fine!
Navigation CD set for Porsche PCM II version 3.0 or higher
Item # PNA 52200305 Porsche PCM 3 disk set 08.2004 edition
$125.00 plus $5.00 shipping.
Edited by BLKPEPA
  • 4 months later...
The AX enterprises NAV CD set is used and out of date. The most current are the 2008 data from Suncoast Parts. The factory set is 329.00 from them. I ordered mine through Hoehn Porsche in Carlsbad, CA and with the PCA discount, the disc set was under 200 dollars. Get the newest available. Plus the discs come in a Porsche leatherette case.
