There is a plastic coolant manifold on the V6 that houses the thermostat and a few sensor connecting to a plastic pipe that runs to the water pump housing in the engine block that can fail. Good thing is that the parts are cheap but it's not the nicest job to replace those units.
Thanks for your detailed reply.
